It is currently Fri Jul 25, 2025 12:39 am
PostPosted: Fri Feb 23, 2007 10:50 am
I want to clean up some old rusty hand planes, and I've read about the electrolysis method using a battery charger and a washing soda solution. My questions for anyone who's done this are: How long should I leave the charger On? And what is the procedure to remove the electrolysized rust?
CrowDuck
Chris Nielsen
Soquel, CA.
PostPosted: Fri Feb 23, 2007 10:59 am
Leave your rusted part a few hours and have a look see, the rust will covert to iron oxide the majority of which will easily scrub off. You can leave stuff over night if you wish, no big deal.
If your part has has paint or japanning such as a plane body, just be aware that prolonged submersion in the electrolyte solution will remove this as well. If you wish to save any painted surface, only treat for 1 or 2 hours at most.
PostPosted: Fri Feb 23, 2007 12:16 pm
I've used electrolysis on 2 of my planes. and it worked like a charm. The length of time you need to leave it is proportional to the amount of rust on the tool . Just remember, as Kim said, electrolysis will remove all jappaning if left long enough. If it's a collectable (non user) you'll want to keep the japanning. another thing to remember is that electrolysis will NOT remove the pits. If there are pits rusted into the tool they're there for good, well, unless you know how to weld.
nay
My blogs
Hand Made Gutar
Woodworker++
PostPosted: Fri Feb 23, 2007 12:30 pm
Chris, If you're at all like me, once you get it set up and running you'll be
finding lots-o-things to de-rust. It's kind of addictive..   especially if
you've got a lot of junk laying around.   Fun with science!!
Long
